Mine starts and runs.Yeah but once I shut it off never started again could be a vaccum leak somewhere
Dose this occur as u hit the gas or let offMine starts and runs.
It only happens some times.
When I hit it. After the 1st rpm.Dose this occur as u hit the gas or let off
Mine does the same thing, I changed coils and wires and its a lot better but still not 100% I'm really confused as to what else to checkBeasGT said:When I hit it. After the 1st rpm.
& as soon as I let it off it runs normal
I don't think its your fuel pump cuz when they go the jus go no warning I've never heard of that happening sorry bud I'm sure someone will have an answer for ya.. maybe its your plugs and wires??When I hit it. After the 1st rpm.
Could have a bad connection on the fuel pump mine did before it shorted out...No codes???
Yes exactly like that!Could have a bad connection on the fuel pump mine did before it shorted out...
Does it drive like its hesitant and gonna run out of gas?
I changed it when I rebuilt the engine.Just because no one else suggested it... When is the last time you changed your fuel filter? Or have you filled up at a new gas station that you usually don't fill up at
Try coils man I'm telling you these mustangs have a lot of the same symptoms. Try both really. I just got over this issue. I would just go through standard procedure and check volt reference to the pump also.Yes exactly like that!
Oh yah change it now!!!I changed it when I rebuilt the engine.
Which was about a year ago.
I think ima try the coilsIf it's been a year, I'd go ahead and change it... Don't take but 15 min, if even that and if it doesn't help then move to the coils. I say that cause my car done somethin similar to that when I first got it... But I don't have individual coils, I have packs
Can't agree moreIf it's been a year, I'd go ahead and change it... Don't take but 15 min, if even that and if it doesn't help then move to the coils. I say that cause my car done somethin similar to that when I first got it... But I don't have individual coils, I have packs
Filter too man they really don't last long...I think ima try the coils
Yes I had a fuel pump issue 1994 cobra. It will let u know if it is badWhen I'm driving my GT the car feels like it is going to shut off. I was told it could be the fuel pump. Anyone have the same problem?
