1 - 9 of 9 Posts
Discussion Starter · #1 ·
Tackled this today. Took maybe an hour total. Car was in driveway on jack stands.
New parts
Cardboard Footwear Material property Box Shoe
Tools
Model car Toy vehicle Collection Vehicle Toy
Removed console
Vehicle Car Auto part Engine Gear shift
Removed old bracket
Light Automotive exterior Bumper Automotive lighting Auto part
Really Ford?!?! I mean really?!?!
Old shifter ready for removal
Auto part Machine Disc brake Vehicle brake Machine tool
Removed
Auto part Engine Automotive engine part Machine Metal
Cup transferred to new shifter
Auto part Hardware accessory
New shifter installed
Auto part Automotive wheel system Wheel Brake Vehicle brake
New bracket installed
Bumper Automotive exterior Automotive exhaust Auto part Muffler
Auto part Machine tool Machine
Ready to instal console
Auto part Engine Vehicle Car Muffler
PITA boot put back on
Auto part Gear Engine Transmission part Hardware accessory
Everything put back together and ready for a test drive
Vehicle Gear shift Car Family car Center console
Test drive was freakin awesome! I love it. Goes into second smooth as butter now. Love the feel it has going into all gears.
How was the install? Any problems getting that rubber sleeve around the shifter??
Discussion Starter · #3 ·
Instal wasn't bad, a little tight but I have large hands too. The 2 post bracket has no rubber sleeve, it's all metal. I had to use a wrench to tighten the bolts on the bottom part but it wasn't bad. It would've been easier with the drive shaft out and if I didn't have a 3" cat-back, but wasn't bad. If by rubber sleeve you mean the shift boot, yeah it was a PITA. I wound up getting the inner part over the shifter base, then used a small pry bar to get the outer part around the metal hole.
When installing the shifter bracket, I've read you have to be "really careful" to not over tighten the nuts or you risk shearing off the bolts. How tight do they really need to be? My initial thought was that if I don't tighten them enough, they will get loose over time, but maybe they really don't need to be very tight? I'm probably over thinking this, but I really don't wanna shear those bolts off (I've read of a couple people who have accidentally done just that...)
I would use your best judgement. Also if you're worried about them coming out, just use some blu loctite and that'll hold them in securely.
I guess my main concern was that these nuts/bolts holding on the bracket would be subject to large forces from the torque of the engine since the bracket is meant to hold the shifter in place and prevent movement.
The screws holding the bracket on the underside are supposed to be tightened carefully, switching from one side to the other as u tighten so the bolt won't snap. Also, it should come with blue locktite
Is the bracket there to make shifts precise and is the shifter there to make the shifts shorter? I feel like just the bracket will do me just fine and save me $200+.
The bracket will take some of the play out of the shifter. It won't be nearly the same as replacing the shifter too but will be an improvement. The aftermarket shifter doesn't just make the shifts shorter. It makes them even more mechanical and precise.
1 - 9 of 9 Posts
