+1Make a list of all possible things that could be causing your problem, then check all those things. If nothing works, start replacing them. From cheapest go most expensive. Or have a technician check it out. I only get a tech when I'm 100% positive I can't fix the problem myself
Wouldn't I notice though if I needed a new belt.I was having the same problem And when I would take off from stop lights and stuff the battery light would flicker then go away. Came out to be bad serpentine belt was all cracked and wasn't catching when I was accerlating. Once I got it fixed no more problem.
+1 with jus a quick glance it'll look fine, because mine wasn't noticeably bad, but bad enough that the belt was slipping and causing the light to flickerif you look the belt over real well you should. but you may not notice just watching it run or with just a quick glance. the best way to really really get a good look is just take it off and go around it looking at the grooves and everything
Damn sorry to hear that..pretty cheap fix if it wasFinally nice enough out so I took off my belt and it looks like brand new. So it's not the belt.
I checked all my grounds, and I tightened them all up and everything. It's not going away. The battery light is solid on.Check all your grounds, also wouldnt hurt to take it to an auto part store and have them test your charging system. Its free and may shed some light on your issue.
Take it and have your charging system tested! It takes 5 minutes and is free.Could I need a new alternator?
I don't have a multimeter but I will do the positive and negative. But it shouldn't be my battery it's brand new, only about 3 weeks old.if you have a Multimeter, start the car, and touch the leads to the positive and negative sides of the battery, if you have only 12 volts then the alternator is not working correctly, anything more than 12 and it is working, but optimal is 14+ volts. (alternately you can just unhook the positive battery cable, if your car keeps running and doesn't die then it is nott your alternator.)
Your batter only starts the car. once the car is started the alternator runs everything and also recharges the battery. Which is why it should read 14v, the extra 2 is what charges the battery.
---------- Post added at 12:24 PM ---------- Previous post was at 12:21 PM ----------
if you don't have a voltmeter/multimeter then do what project pony said and have the friggin system checked at autozone...
if you figure out its not the alternator using the multimeter then you have to start looking at other things.
When you crank it, does it take a bit to crank or does it start right up?
If so then my opinion is it probably isn't your battery and you should check out your gauge cluster
