1 - 7 of 7 Posts
· Registered
Discussion Starter · #1 ·
So I got my 96 back together hooked everything up and went to start it up, I put the key in the ignition and all the lights came but when I turned the key I heard a single click then all the lights went dim. I know 100% that there's nothing wrong with the starter. What could it be?
· Registered
That click is the starter solinoid connecting... Most likely your batter is low. Charge your battery and then try.. Have you had to disconnect the battery for some reason?! And maybe taken it out and put it on concreate?! Because concrete will drain your battery
· Registered
Discussion Starter · #3 ·
I've had it charging all night, I tried again and the engine turned over this time. Tried it a second time and all the lights dimmed and nothing else happened.
1 - 7 of 7 Posts
