1 - 13 of 13 Posts
Discussion Starter · #1 ·
Is it normal on our cars to have the battery light flicker on and off once in a while. It's been doing that and today it stayed on for like 15 seconds while driving at night with radio and lights on. Never done that before just wld flicker. I have checked my volts and running they are constantly over 14 volts. My battery is good and my connections are very clean. I have read of other mustangs with this problems so is this normal???
On the same note of battery question is it normal for a Mustang to be dead if not driven for 2-3 days? 24 hrs is ok but anything more than that I need to jump it once in the am. Once jumped it operates fine until it sits for more than 24 hours. Battery gauge shows normal.
Discussion Starter · #5 ·
From the looks of it its not normal. I let mine sit two weeks and when it was time it started fine the first time. Does your battery go uncharged just sitting? Is it old? What's ur climate like? Or is something draining ur battery?
Polar Bear---Bring it to somewhere like advance auto, there dumb as hell but have them hook up the battery and alternator tester to your car they can check everything at once with one machine, and get results in 3 min and its free! Sounds like your battery though when it gets cold your battery's performance is going to drop.
charlie03fastGT----- I would recommenced the same thing (except your battery isn't the issue) but before that i would check all the connections to the alternator and battery make sure there are no loose connections or bad grounds or anything loose it can be a pain but better it be a free loose wire or bad connection than it be a bad $120 alternator.
If you end up needing an alternator, buy one at Advance auto parts online, use a coupon code, and pick it up. The guys at my local Advance hates me because I never pay anywhere close to what I should.
Discussion Starter · #12 ·
Lol. Advance auto hasn't hit my area yet. I do run an autozone though and have access to any alternator brand I want. I am thinking Motorcraft. Plus discount :)
It is also normal IF the battery has a weak cell. Weak cells can output their share of the voltage under no or low load, however they cannot provide the rated current (amperage). Get the battery load tested or check the voltage while cranking the engine--it should not fall below 10.5 V while cranking...
1 - 13 of 13 Posts
