1 - 20 of 38 Posts
· Registered
Discussion Starter · #3 ·
yeah mine was like that. the red cover keep me from noticing the defective battery.
You need to replace the entire wiring harness. looks like this.
View attachment 304536 View attachment 304536
That is what im afraid of, uninstalling and installing time and labor is not something i think i can do on a ramp. I was thinking cutting the tape and dip it in baking soda and water for couple minute then wrap it up again.
· Administrator
I would strip back the loom and cable insulation to see how far it runs. If cleaning doesn’t work out, you may be able to remove a section of the cable, make repairs. I’d hate to have replace that harness, it’s bound to be expensive.
  • Like
Reactions: Beechkid
· Registered
Discussion Starter · #5 ·
When i strip it back the corrosion is not bad, its only about less than an inch down the copper wires. I used alot of baking soda mixed with water, i even dipped it in it but somehow i can only get 90% of corrosion off. Theres still some blue stuff stuck on wires that toothbrush cant even get off. Im going to try battery corrosion cleaner see if its helps.
· Administrator
I’ve used the corrosion cleaner (messy stuff) on mine, and it worked out well, but you need to get that cable super-clean. I purchased some small (toothbrush sized) wire brushes from Lowes and went to work. It was actually pretty time-consuming but worth it.
  • Like
Reactions: Beechkid
· Registered
Discussion Starter · #7 ·
i feel wire brush are too harsh on copper wires, wouldnt it easily scratches and possibly weakens the copper wires? Yea i also got corossion preventative spray after im done cleaning.
· Administrator
It won’t hurt the wires. Get one with brass bristles if you’re worried about that. The corrosion does more damage than a brush ever will.
  • Like
Reactions: Beechkid
· Registered
Discussion Starter · #9 ·
from google it saying brass is stronger than copper, wouldnt it scratch the heck out of the copper wires? I have one of those battery terminal brush but doesnt seem suitable for copper wires.
· Administrator
Yeah, brass is more mild than steel, but still harder than copper. You are going to scrape and scratch the corrosion off, so some minor scratches to the outer surfaces of wire strands will hurt nothing, unless the cable is nearly corroded through to the point of breaking. And if that’s the case, it just needs to be replaced. It’s just not that delicate In my opinion. If you want it to be factory pristine, then you may as well just forget about cleaning it up, and just replace everything.
They’re really isn’t too many options here. Cleanup it and repair it, or just replace it. I think you are worrying to much about scratching the wire strands.
If you can get the corrosion removed and neutralized by dipping and scrubbing with a nylon brush, then that’s fine too.
  • Like
Reactions: Beechkid
· Registered
Discussion Starter · #11 ·
Yeah, brass it more mild than steel, but still harder than copper. You are going to scrape and scratch the corrosion off, so some minor scratches to the outer surfaces of wire strands will hurt nothing, unless the cable is nearly corroded through to the point of breaking. And if that’s the case, it just needs to be replaced. It’s just not that delicate In my opinion. If you want it to be factory pristine, then you may as well just forget about cleaning it up, and just replace everything.
should i use copper bristle brush instead lol? will it still get the corrosion off?
· Administrator
I guess a copper brush could be used too … I’m not sure how effective that would be, or where you would find one. Have you actually seen them available somewhere? That would be akin to rubbing a bunch of copper wires together lol. In every shop I’ve worked in, a wire brush was the way (with regards to cleaning). That’s been several decades ago, but I doubt things have changed that much. Perhaps they have.
Look at the thickness (thinness) of the battery terminal on the wire cable. Look at the scratches on it. Now look at the thickness of the copper cable it’s wrapped around. If scratching the surface up were a problem, do you think that battery terminal brush would be made of Steele?
Of course a dealership would never make a repair on this, they’d replace the whole shebang-abang, as would any other pro-shop. They don’t want to have any come-backs, and it’s your money, not theirs.
· Registered
Discussion Starter · #13 ·
I found some copper brush bristle online but not sure if its effective lol. The battery terminal brush is very harsh it actually scraps layers of terminal off when using it. Yea i would replace it too if it wasnt the whole startup harness all connected to it.
· Administrator
I think you’re being overly cautious, but I understand. The cable is thick enough, that removing a small amount of material by brushing with a steel or brass bristled brush is inconsequential. I’ve done this exact procedure at least 50 times (probably more), and the only side effect was a clean/shiny surface without corrosion.
In any case, when you do get it cleaned up properly, please post a pic. We really need activity on this forum (Just say’n). :)
· Registered
Look at picture 2 in my first post. The copper terminal clamp was ate up from acid.
I had cleaned the wires as best as I could and tightened the clamp back and it cracked.
Thats when I just got a new one from ford. about $150. I think. Had a mechanic
change it out for 2 hrs labor. Its a very delicate set up and needs to be perfect.
· Administrator
If the clamp is cracked, clearly that needs to be replaced. I didn’t notice it in the pic, as I’m on a mobile device with a small screen. Since you pointed that out, I see it. Thanks for sharing.
· Registered
Discussion Starter · #17 ·
Last night an idea popped in my head, instead of searching for battery corrosion solutions i searched for copper corrosion solution instead. All of solution for battery corrosion are the same but none says anything about the cables. Searching for copper corrosion i found new valuable information that i can think can help anyone else whos also in the same situation im in. Baking soda and water will only neutralize the corrosion but will not completely get rid of it, what i found is in order to get rid of corrosion on copper wires you need a mixture of vinegar and salt. Within a minute of dipping it in vinegar and salt the corrosion completely went away. As you can see the new shinning almost new copper wires. After you see all the corrosion gone dip it in baking soda and water for extra protection then spray it down with corrosion preventative spray. As for right now i only wrapped it down with electrical tape 33+, after couple weeks or so ill check again for corrosion. If theres no more corrosion im going to us heat shrink tube to permanetely seal it up.
I used a cup of white vinegar and a couple teaspoons of salt to do the trick.
Tire Hood Automotive tire Motor vehicle Vehicle
Hand Fluid Bicycle handlebar Finger Automotive tire
Hand Light Hood Camera lens Automotive tire
1 - 20 of 38 Posts
