1 - 5 of 5 Posts
· Registered
Discussion Starter · #1 ·
I took off my old serpentine belt because my a/c compressor went out and I didn't want my belt to break so I bought the same belt for my model only w/out a/c and it doesn't even fit. What could be the problem? Am I better off buying a ford racing a/c pulley replacement?? PLS HELP, thanks!!
· Registered
If you want to run the oem length belt get a ac/delete pulley. Or do as stated with the string and bypass that and the smog pump.
· Premium Member
You can reroute the factory belt to work without ac...
1 - 5 of 5 Posts
