1 - 13 of 13 Posts
Discussion Starter · #1 · (Edited)
what kinda numbers?
i'm getting a custom true dual setup on the mustang and wondered what the numbers i'm looking at are.
all aluminum with flowmaster 40's
dual exhaust is a mod that allows for better airflow so hp is increased that way. So when you do more mods, your dual exhaust will allow for more hp to be made.
What would longtubes and a catted mid-pipe and I'm thinking of Flowmaster (40's) make me?
4 hp? :uhh:
4 hp? :uhh:
LTS maybe 5rwhp and you would lose a little tq at your peak about the same maybe a little more but higher up in the power band.
NO cats once again wotn help at all maybe a little hp but it will kill your down low power... it will move the tq peak up a good bit
all mufflers are about the same
So you gain some and lose some, but is it worth it?
(I'm thinking of staying NA)
Ya, it's worth it. 3.8 engine have kinda high toque. Well higher than any 4 cylinder so I'm sure you could spare a few tq for a few extra hp. And if you're that worried about tq, go with a 4.2 swap which will give you about 30 more tq and maybe 5 more 5hp too.
Guess I got to do that after the full exhaust change, thanks man. Then the intakes, cam and heads.
Well what year 3.8 are we talking. Also you need to specify a cam. My 97 put out roughly 210 bhp and about 260 btq when i did my h/c/i swap. I went with a 216/225 cam then. Now I have a 224/230 cam, and a 4.2 w/ Bigger valve heads. That's how I have so much more hp. And i still have some work to do. I think once i get my new intake built with some long tubes I should easily have 300 bhp.
1 - 13 of 13 Posts
