Blinking Check Engine Light - 2012 v6
608 Views 6 Replies 6 Participants Last post by  iguanaman3
So I have a 2012 v6 mustang no start no crank out the blue I changed the battery an starter still no start no crank I see the anti theft light flashing multiple times when key is engaged an check engine light flashed 6 times what does it mean tired to reset the theft light but no start still relay sounded lik it clicked when key turned but no crank no noise when tryn to start
1 - 7 of 7 Posts
Welcome and thank you for joining MustangEvolution!
Please read the Site Rules if you haven’t already.
I encourage you to complete your Account Settings.
If you need help posting? Please read this FAQ.
We’re happy you’ve chosen to join our community.
Someone will be along shortly to offer advice.
The only time i've had the theft light and CEL flash together is when i used my doorlock-only key to try and start my car.
Only thing i can think of.
  • Like
Reactions: 1
If you have a second key try it, that is what happens when the door key I have for the F650 is used in the ignition. Your key might be going bad. Also changing out the battery will not help the chip, it is seperate from the electric functions of the key.
  • Like
Reactions: 1
That's anti theft at work. I agree with the above conclusions. When you say changed the battery do you mean in the remote or in the car? Changing the battery in the remote or, at least checking its voltage and verifying is step one with anything like this. This is why I make multiple keys and program them for all modern cars. Get a glitchy one and it'll do this. If you've got just one key, you may be out of luck and need to get the car to the dealer..
  • Like
Reactions: 1
The Chip is self contained, I have had my Fob on my Mustang Key pulled apart because the panic button was stuck on and everytime you got close it would go off. All they did was take a Key and the Fob and make it into one thing, still separate though.
This can be because your PCM is not communicating or is not powered up. Check all the fuses that power the PCM.
Check this out...
  • Like
Reactions: 1
1 - 7 of 7 Posts
