1 - 8 of 8 Posts
Discussion Starter #1
Today I remove the front headlight assembly on my fox body and on the driver side there is a little fiberglass damage which should not be a problem with my expertise in this field I am slightly stuffy the paint and applying filler primer I am also removing all moldings
Discussion Starter #2
I am going to go with a green primer and I am going to paint the moldings flat black and I am going to get the pony wheels when I am finished it will look pretty nice I am going with a Cobra R hood also
Discussion Starter #8
Thanks I cannot work today due to the rain that has been going on for the last past 3 days... What I'm doing is scuffing the original paint and applying rust Oleum edging primer after letting it dry for 2 days and scuff it then I will apply filler primer generously after that dries sand it with 220grit wet with a block 1 of those rubber squeegee you use for color sending would do just fine remember maintaining body line key. I will also be showing how 2 properly mask a car
1 - 8 of 8 Posts
