1 - 20 of 41 Posts
Banned
Discussion Starter · #1 ·
It will work for my 96 correct? lol
How hard is one of these to install. I think Brandon(SpectorV) has installed one on his previous Mustang so maybe he can help me with it. What are all the steps? I really want to do this myself as I have a Dig Camera now and want to maeka write up on it.
Banned
Discussion Starter · #3 ·
01mineralgrey6 said:
you have to pull the tranny pan, drop the valve body, change some springs, and hte accumulator (sp?), drill some holes in the seperator plate, etc...etc, the instructions will explain it better;)
lol didnt know there were step by step instructions :woot:
Brent, be careful, be clean, make sure you clean all drill cuttings off there good before you put it back together, follow instructions closely, change the filter in your transmission while you have the valve body out and replace all the fluid you can drain.
You want to **** me?
dude, its worth the perfect install... dont mess around when it comes to things that you dont have experience with. Installing a valve body shift kit for the first time is probably not the smartest thing... just my opinion.
Dude I am not suggesting you are not mechanically inclined or anything but unless you have a lift to be able to work with little trouble, doing tranny work on your back under the car sucks big time. I have been doing all levels of car work for 20+ years and I would not do a Valvebody change on my back with little or no room to work. Maybe you know someone with a car lift!!!!
1 - 20 of 41 Posts
