just upgraded to cobra calipers and for some reason ONLY when i am rolling backwards and taping the brake it makes a clunking noise sounds like the front right but could be the master cylinder, I will investigate tonight to see where its from but its only in reverse? I can go forward and tap it adn its fine but barly going back it will do it?
I have sloted and drilled rotors also.
the calipers may need to be bleed again... if you think that will help.
