1 - 13 of 13 Posts
Discussion Starter #1
I can't stand it anymore. I have replaced my pads to ceramic, put new rotors and hardware on and they still squeak! Anyone help?
Discussion Starter #3
How long is that?
Discussion Starter #5
Ill give it one more week since I changed them before thanksgiving. But it squeaks when they get warm and when I give medium braking power. When I brake hard it goes away but when they get warm they start to squeak
did you lube all the slides and any part of the pad making contact with the caliper? if not that'll make them squeal like a pig.
Discussion Starter #7
Yeah I did but ill do it again. It can't hurt
what brand brake pads btw? when i did my last brake swap i used some cheap ceramics and well they squealed so i ordered some Hawk pads online and they are doing great
Discussion Starter #9
They're dura last ceramic pads on oreillys brand rotors.
when you put the rotors on did you completely spray them down with brake parts cleaner and wipe the shipping oil off?
Discussion Starter #11
Yes sir. I have done everything except replace the rotor. I'm thinking get new hardware and re oil the slides
worse case scenario go to autozone and tell them they squeal like crazy and you want to swap...see if another pair does better
Discussion Starter #13
I'm not sure if I should return the oreillys rotors or autozone pads?
1 - 13 of 13 Posts
