On 94-95 GT's is there more braking force in the front or rear? I'm thinking front or maybe even 50/50 but I may be wrong...
The bias is always towards the front brakes, otherwise the back brakes could lock and cause an uncontrollable skid.On 94-95 GT's is there more braking force in the front or rear? I'm thinking front or maybe even 50/50 but I may be wrong...
Ok cool. Reason I'm asking is...to save some money I was thinking of keeping the rear rotors stock and going slotted up front with hawk pads all the way aroundTrojan Horse said:The bias is always towards the front brakes, otherwise the back brakes could lock and cause an uncontrollable skid.
The exact bias depends on the brakes used, weight of the car, etc., etc.. The proportions are different for disk and drum brakes, which is why when converting an older Mustang to rear disk brakes you need to change the master cylinder and proportioning valve.
Hawk makes slotted and UV coated replacement rotors for 190 a pair so I was going to turn the rears and put these on the front. I was also going to run Hawk pads (street/track pads) on all four corners.SpectorV said:slotted/drilled wont really do anything for stopping with OEM style pads, but they will look different. If they are not coated they will rust like crazy FYI (you can paint them with high temp engine paint (every inch of them if you wish) after you remove any oil from them from the factory.
That's what I bought the car fordreamstang said:Yeah the benifits of a drilled/slotted rotor are just cooling. They are great for auto x where a lot of hard breaking is going on.
