41 - 60 of 82 Posts
My bone stock auto 4.0 could do a break stand burnout no problem
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Yes it's tuned. I just power brake until the tires start to spin, then let off the brakes and floor it.
Sent from my HTC One_M8 using Mustang Evolution mobile app
Last day I tried doing burnout at first nothing happened the rpm got stuck around 2000. I had forgotten to close the advance trac however traction control was off. Later on I did the method that someone has explained in this topic and it worked. Shifted up to 3 in sport mode and then lowered the gears to 1 and it started to do a burnout. The car is an auto.
Abominable Mustang
There is a trick to do a burnout. Turn advancetrac fully off then put the car in sport mode and shift up to third gear while still standing still. Then floor the gas while holding the brake and downshift into 1st. You will do a burnout.
I can't see these being good on a transmission at all, even as just a once in a while thing. It's much safer to get the torque management deactivated with a tune.
JUST DID IT.. This work. Thanks bro
I would stay away from this method as there is no way of knowing what kind of damage it is doing to your transmission.
Manuals have sport mode too. FYI
Thanks for the info.
So you have to press the stability control button twice? Is that correct?
Are all later model manuals equipped with this feature?
While holding the brake press the button twice. But the sports mode on the automatic is referring to shifting it into S with higher shift points or manual shifting.
Do some research man ! Manuals do have sport mode !! I have sport mode on my manual
2011 Mustang GTCS
BBK CAI
Lethal Performance Off-Road X-Pipe (kept my cats on)
DMH Performance Electric Cutouts
Flowmaster AxleBacks
Yup !! See that guy knows ^^^
2011 Mustang GTCS
BBK CAI
Does that mean that my 2012 v6 manual as as sport mode and I didn't know ?? How do you activate this ?
Thanks
Airaid Bama tune/Hood strut/MBRP axel back
Thanks
Press the brake and double tap the traction control button and sport mode should appear on your gauge
2011 Mustang GTCS
BBK CAI
Not all V6's are equipped with Sport Mode.
"AdvanceTrac Sport Mode
• AdvanceTrac is standard and includes Sport Mode
on GT Premium models and with available V6
Performance Package
• Sport Mode is a unique calibration of AdvanceTrac,
allowing for more spirited driving with AdvanceTrac
still enabled."
Yes some V6 Manuals do have Sport Mode, as Diehard said, it just turns the nannies down but not off.
Thanks guys ! Can you Believe i've had my Mustang for more than year and I didn't know that ! :)
All 3.7s with the performance pack have the advancetrac sport mode. Base models do not. Press the brake in and double tap the traction control button
41 - 60 of 82 Posts
