I'm not sure the governor would be causing any slippage though. If the motor did not allow the engine to brake in 1st or 2nd then yes this could be an area to explore.........since it doesn't I'm just not sure this a direction to go.If there is no engine braking I believe that's a gummed up governor. It's buried in the tail housing so the whole trans has to come apart, I remember when I put mine together it was stressed that the piston in there should be absolutely free to move. If it won't move by just shaking it a little bit it's gummed up. Does this sound right olerodder? I don't want to send anyone on a wild goose chase. I'm going off of memory and mine isn't very good
Smoke tires not drugs
