1 - 1 of 1 Posts
Discussion Starter · #1 ·
Good luck with your installation. Remember to align first, snug up on it, check all clearances around fuel lines, hoses, rear axle, fuel tank, align again, double-check, then tighten. If you can weld, it's a safe bet to weld all the places where the pipes meet each other. It's not a must and makes for a messy dissasembly because of the need to cut the pipes, but it will be much stronger. Have fun, and be careful.
1 - 1 of 1 Posts
