as the topic says...can it be done? 99+ v6 we're talkin here.
thanks!
thanks!
Danger Dude said:Radiator does not have to come out only have to take off the fan. The 3.8 cam is not very long and easily passes between the motor and the Radiator. I did it !!!!!
No I haven't. But the picture i saw of it, they guy did take the radiator out.stangin99 said:ummm Dom, have you ever done the swap?
To swap a cam, you need to pull:
Upper, Lower, waterpump/front cover, power steering PULLEY only, and then you take off the timing chain and some other things and the cam slides right out.
edit: Taking the fan out gives you a good couple more inches of room to work. But the radiator can stay.
ridelikehell said:i know you need to pull the heads, intakes and all that s**t out, I just don't have an engine hoist and I don't wanna pay an arm an a leg for something that I can do myself as I've done cam swaps before, I just wanted to make sure there was enough clearance, I have no problems taking out the rad if need be, but i'll cross that bridge when I come to it.
Thanks for your help everyone!
how does what you just said have anything to do with your first reply..in your first reply you said what has to come off...how does that entail me sitting there and wondering what i wasted time and money on?...which I wouldn't mind you explaining to me seeing as I have no idea why that will be a waste of my time...stangin99 said:did you even read my first reply?
if you pull the heads and all your accessories, your going to sit there and wonder why you just wasted all that time and money on new head gaskets/bolts.
thanks for your help man...about a hoist i was just saying that i don't have one, so if the cam swap meant i had to remove the engine then i wouldn't be able to...but since it doesn't have to come out im good...Danger Dude said:To pull the cam you dont need to take off the heads. But most people are changing the heads when they do a cam. What is this about a hoist. Totally unecessary unless you are taking out the entire engine !!!! hell the aluminum heads dont weight squat. The biggest concern is the Cam position sensor. You need to make sure you are top dead center when you disassemble. The CPS has got to go in exactly as it cam out or your car wont start or run very very bad. It send the signal to the coil pack for proper spark timing
oh right on I didn't know they couldn't be reused...thanks!.....Danger Dude said:If you take your heads off which you dont to just change a cam you need new head bolts. Head bolts are really a one time use item as are gaskets and such
ridelikehell said:thanks for your help man...about a hoist i was just saying that i don't have one, so if the cam swap meant i had to remove the engine then i wouldn't be able to...but since it doesn't have to come out im good...Danger Dude said:To pull the cam you dont need to take off the heads. But most people are changing the heads when they do a cam. What is this about a hoist. Totally unecessary unless you are taking out the entire engine !!!! hell the aluminum heads dont weight squat. The biggest concern is the Cam position sensor. You need to make sure you are top dead center when you disassemble. The CPS has got to go in exactly as it cam out or your car wont start or run very very bad. It send the signal to the coil pack for proper spark timing
except for the fact that stangin99 thinks i'll be wasting my time, which im hoping he'll explain to me.
that you know you have to take the heads off :-?know you need to pull the heads, intakes and all that s**t out, I just don't have an engine hoist and I don't wanna pay an arm an a leg for something that I can do myself as I've done cam swaps before, I just wanted to make sure there was enough clearance, I have no problems taking out the rad if need be, but i'll cross that bridge when I come to it.
