1 - 20 of 31 Posts
Discussion Starter #1
Discussion Starter #2
Can ya help me out??
Discussion Starter #4
Don't know how I'd go about that. Tips?? Lol
Discussion Starter #5
I think I'm being picky. It's probably just from sitting overnight
Discussion Starter #8
That the like serious way to do it?? Lol ill have to do it after work
Discussion Starter #11
It says let idle till gets to temperature. That mean let the temp needle get where it's supposed to be or just let it get down to it normal idle after starting it?
Just let it go to normal temp. I just let it idle for a little bit while I did something else then it was at normal driving temp when I got back in
Discussion Starter #13
ok, noted. im gonna do this as i get off work
Discussion Starter #15
its all good, i work at a parts store. that means professional right?? haha i crack me up
Discussion Starter #16
After I drive it for ten miles can I drive it more or do I need to kill it after ten miles
Try this next time:
-Turn the key to start, do not start.
-Turn the key off.
-Turn the key to start again, this time crank the engine. Does it crank right up? Bet it does. Guess you know what that means. I am having same problem only worse. Pending a 255 LPH fuel pump to keep up with my aftermarkets. It did it before upgrades, now just worse.
Discussion Starter #18
It always cranks right up just right after I start it there's a very quick hesitation that's been getting on my nerves lol
Discussion Starter #20
It's not throwing a code. What TSB
1 - 20 of 31 Posts
