1 - 3 of 3 Posts
Discussion Starter · #1 ·
i have a 1985 mustang 5.0 L carb and i want to maybe add a turbocharger or something. can i do this with this car???????
look i have the same car with only 1800 miles if you want to make it go faster off the light change the rear axle the car came stock with a 2.73 i have the factory option of a 3.08 the lower the number the less of an major acceleration but you will turn higher RPM'S with a higher axle and you will get less gas milage a 3.55 will work also don't change that car to much that is the last of the carb mustangs it will be worth some $$$$ later on
If you have $3000 to burn, and that is just the parts. Labor for the installation is another story. Car is not worth it.
1 - 3 of 3 Posts
