61 - 65 of 65 Posts
Discussion Starter #61
To everyone reading I've realized that the shop did not connect the purge valve connection...it was just hanging there. Could that be the reason for all my problems??
Yes. That is probably the cause of the 1450 code.
I'm not sure what is going on with that kinked tubing in the picture but you should try to repair that also.
Discussion Starter #63
I'm debating if I should buy the install kit that comes with a new purge valve and hoses or if I should just go to the parts store and get some hoses because of that kink on that purge tube
Replacing the O2 sensors should do it. But this will happen again because of the headers.
Never ever use the extensions. Are you running E85? That makes things worst.
Do you know the fix for this? I replaced my O2’s it was fine for about 2 months and just
Got P2197 code
61 - 65 of 65 Posts
