The car starts fine and drives fine, but when in city traffic it will sputter, cough and shut down after 15-25 minutes. I thought is was fuel level related as it always happened just below 1/4 tank, but happened twice yesterday, 2nd time after a fill up. It will just turn over and over like it needs fuel. Finally after trying to flood and spraying a lot of carb cleaner down the throat, it starts and runs, drove 15 minutes home, (took about 15 minutes to re-start).
67 289, edelbrock performer intake, Holley 570 Avenger, mild cam, edelbrock fuel pump, power brakes, manual steering, C-4 (2300 stall), 9" 3.50 posi. Timing 14 BTDC, Vacuum 19-20, idle at 650-700. just changed plugs and were clean, mixture 1 3/4 out each side, fuel pressure was 6 psi, but then went to 0 and I drove it 15 minutes home, still 0 at home (gauge probably hot). After it died, I can see fuel squirt in the carb and the fuel bowls were adjusted to just leak when screw removed (both bowls), Engine temp gets to 200 to 205 in traffic.
