What could possibly cause your entire electrical system to shut down when turning the ignition key to attempt to start the car, you hear one click from the starter and the electrical system completely dies until you pop the hood check all the fuses under the hood and on the passengers side, car is only 4 years old, battery is pretty new within a year, the cable was a bit corroded once cleaning off and replacing the car was able to power up and start after resetting the battery. So a corroded or bad battery cable could cause your electrical system to short when trying to start? I figured if it didn't get enough amps it just wouldn't start but not kill your entire electrical system until you unplugged and replugged the terminals.
