As all of you know my fuel pump died.
My buddy "matt'sdrag95" gave me his gas tank which had his stock fuel pump in it. He said it worked fine.
So i got it. I dropped my tank, and i was going to switch pumps, but his tank had alot less rust and wear on it so i just used his tank.
About a month ago, i took my old tank off. Left the lines down ect cause i never had enough time to go out there and put the new tank in.
I got out of work early today so i raised the new tank up.
Plugged in the harness. (i bought a new rubber gasket where the spout neck goes into the gas tank cause the other one was cracking. Stuck that in Stuck the filler neck in. Put in that white thing that goes in the hole have no idea what that is. Pluged in the fuel lines, clamed them.
Bolted up the tank. Bolted up the filler neck. Filled it up with as much gas as i could fit in my hand held tank. (6.5 gallons)
Tried to start it.
It goes like it has the power to start but it doesnt turn over.
I also plugged back in the fuel pump plug that you unplug to release the gas pressure)
I knew there was no pressure and it would take a while, but i kept cranking it. waited 5 minutes cranked it alot again, while pushing the gas...
still it just cranks, but it wont fire up.
Dont know what else to do, what else to check...
help?
Tried to start it.
help?
