1 - 8 of 8 Posts
Discussion Starter #1
I was at the car wash yesterday never had a problem starting till after I finished detailing it. It then would not crank on. Batteries not dead everything still works. Checked all the obvious and still nothing. Any suggestions?
Did you activate the security system or something accidentally ?
Does it do anything at all when you try to turn the key? Any lights come on like normal or do you just turn the key and it acts absolutely dead?
Discussion Starter #5
When I put the key in and turn it everything works I can hear the fuel pump and everything. It just won't crank at all
Does it try to turn over?
Is it Manual or Auto? It could be the switch on the clutch, when it's not all the way down. Or if Auto, it could be the switch indicating the car is in park.
Discussion Starter #8
It's manual and yes it was the switch on the clutch. Clutch doesn't push it far enough anymore
1 - 8 of 8 Posts
