There is some good carb vs efi information/comparisons in the stickies.
IMO I wouldnt convert unless you already have some of the required parts.
The tuning and maintenance will be much easier will be less of a headach on efi than a carb. Power wise would be similar all depending on setup.
To convert, a few things you will need:
- A fuel pump or way of SAFELY regulating it down. Mine currently is regulated down. it does work good without any issues. But that maybe because og doesn't get a lot of miles on it.
- a fuel pump regulator.
- a fuel pump relay. I used the factory relay and took the signal wire that usually tells the relay to kick on and put it straight to ground. This makes it kick on when the key is forward.
- this isn't necessary but I installed a kill switch because of the previous statement.
-You will also need a distributor because the stock one will not advance anymore. You can use a vacuum or centrifugal advance type.
- then the obvious. Carb and intake.
I maybe missing some things. But if your not worried about tuning and maintenance I would weigh the prices of the above mentioned over: injectors, throttle body, and whatever else would need purchased for supporting mods.
Also a wideband isn't necessary but will help tuning. I thought my car was tuned perfect. It ran great, with perfect throttle response. Until I installed the wideband. I have since changed the jets 4 sizes and maybe need just a few more. But I just haven't for that far because I recently found out my lifters where shot.
Hope this helps.
