The rears I got from the same place. They are on this page. $46.95 per.01mineralgrey6 said:I was looking at getting the Zinc coated slotted ones with the red pony calipers when ever i need brakes....Did you get the new rear rotors from the same place? I guess i can just paint my rear calipers red. Thanks for the information guys. Thats definately on my list of things to do.![]()
Did you have ABS? if i bought those would I be able to use my ABS with them? I reall ydont want to give that up its so nice lolLaser02 said:Almost too nice. Without ABS, I can lock up the brakes really easy.
The brake lines were probably the most annoying part. Not hard. Just annoying. There is a bracket that was holding the stock brake lines in place... It had a hole, but the hole was not perfectly circle. It had a notch in it. Well. The new brake lines didn't want to fit in the hole with that notch thing there. I removed the bracket and put it in a vice and used a dremel to grind the notch off. Worked fine after that. It took me five hours but at least 1 1/2 hours of that was just getting the wheels off. Had some lugs nuts that welded themselves to the studs.SpectorV said:i ordered a full front set from diskbrakesrus powder coated red with running pony on the front 13 inch 01 up cobra brakes and powder coated rotors cross drilled and sloted with ss lines, I hope they get here soon i want to get them on. did the new brake lines just bolt right into place with ease? any tips on installing other than normal take caliper off and put stuff on type deal?
