1 - 5 of 5 Posts
Discussion Starter · #1 ·
My 98 3.8 v6 is giving me a P0131 and P0443 had to replace IAC because it was damaged on the inside and replace all vacuum lines all the way to canister, just looking for a little direction or anybody that has had these codes before, still reading into what VMV circuit fault is but just thought I'd see If anybody had any helpful info . Thanks!!!!
Hi, the DTC , po131 is O2 sensor on bank 1. and the po443 is the purge control valve. Check the purge control solenoid to make sure it is working .the solenoid maybe causing your car to run lean or rich. throwing off the O2.
Discussion Starter · #4 ·
Replaced purge valve solenoid and got rid of 443 code still reading the 131 code but CEL hasn't come back on yet only driven it twice since I deleted codes and replaced solenoid
1 - 5 of 5 Posts
