1 - 11 of 11 Posts
· Premium Member
Just don't have your head under it when you pop them off. Gas is not a good flavor
· Registered
Without a doubt 100% get the disconnect tool for a new edge, I thought I could get by without, I tugged and tugged and those lines would NOT come apart, went and got the 7$ disconnect tool and had it done in 5 minutes....make sure you bleed the gas valve in the engine bay, it's in front of the TB looks like a tire valve..the more you bleed that when you disconnect the fuel switch in the trunk, the less gas will come spewing out of the filter upon removal
1 - 11 of 11 Posts
