1 - 5 of 5 Posts
Discussion Starter · #1 ·
How the heck do you change transmission fluid on a 08 v6 manual? Ive seen a bunch of different ways to do it but I have yet to see any that look like mine. Would I have to take out the transmission? Has anyone done it on this car specifically?
There's a drain plug and fill plug usually located inches from each other. Just do as the plug says. I first open the fill plug and stick my finger in to see if its low, and make sure it's not seized; if you can feel fluid it's full. Drain the oil into a catch pan and then fill the case until oil starts to drain back out. You may need a pump to get the fluid into the fill hole. A simple hand pump will suffice. Make sure you get the proper fluid and an adequate brand.
TRANSMISSION
You did say V6 Manual right?:confused:
I sent you a Private message.
1 - 5 of 5 Posts
