1 - 20 of 31 Posts
· Registered
Discussion Starter · #3 ·
Don't know at this moment
---------- Post added at 12:17 PM ---------- Previous post was at 12:15 PM ----------
Can't check it right now, waiting for my friend to get off so I can plug it up and see
· Registered
Discussion Starter · #7 ·
Got check engine light checked, and code shows p0156 to rich or to lean, eliminated my cats and the check engine light came on, put on mil eliminators that I got from someone last week and light went out for one day and came back on, could the mils be bad or could my rear 02 sensors be bad.
· Registered
Most likely its bad 02 sensor. I had a p0158 for 2 weeks every time I would shut it off it would come back on turned out bad 02 It came on right after I did a tune up so I thought it had something to do with that turned out just coincedence it could just b coincedence that it happened after the mil Eliminators. What I did was swapped the wires on the 02 sensors so bank 1 is reading the bank 2 sensor and bank 2 sensor is reading the bank 1 sensor if the code changes to the oppossite bank u found your problem its more then likely the 02 sensor. That's how I narrowed it down. But while I was down there I just replaced both it was worth it at only 48 bucks a piece.
· Registered
Passenger side rear o2 sensor near stock h pipe.
---------- Post added at 04:41 PM ---------- Previous post was at 04:40 PM ----------
Take a wire wheel or wire brush clean off the carbon put back in reset cel by disconnecting battery for 15-20min then start up see if it comes back before buyi a new one
· Registered
pretty sure bank #2 is on the driver side, since cylinder one is on the passenger side the passenger side would be bank #1, just imo i could be wrong and i dont mind being corrected.
1 - 20 of 31 Posts
