1 - 8 of 8 Posts
Discussion Starter · #1 ·
got it and the grille delete from mustang tuning. and i wanted to know what size drill bit i should use to drill the holes for it if i use the included hardware? will post pics tomorrow before i go outta town once its on.
Discussion Starter · #3 ·
i'll see what i have tomorrow and figure it out. should i base it on the width of the screws or what?
i dont knopw since ive never installed one, but just look at the screws it comes with and compare them to your drill bits.
when in doubt go to small, i think its 1/8th or 1/4th i belive it comes with instructions and hard ware (or should) the key is get a friend to help hold it up, even it off side to side, dont just line it up on one side else the other will have a larger gap, you can pull it back off the front edge to line it up on the sides ( go all the way back ) or you can sacrifice a quarter inch perside~ and have it line up on the outer edge of the bumper (what i would do) just make SURE it doesnt stick out past the bumper....
1 - 8 of 8 Posts
