1 - 10 of 10 Posts
Discussion Starter #1
Well I got the motor out heads off and all accessories timing cover and cam out and I am gonna clean the block what should I use it's all grimy but no blow by and the Cylinder walls look great rings also
Discussion Starter #4
rwsmith3623 said:
Are you planning on using water?
I would like to avoid using water
Banned
Won't hurt it. Use HOT water and soap to loosen and dissolve the grunge, rinse with hot water and blow dry.
Grab a set of block cleaning brushes and pay particular attention to all of the oil passages to get the crud out of them.
Discussion Starter #6
How much would it cost to get the block honed at a machine shop and cleaned
Excuse me for butting in to your thread. What is the best way to clean a running engine? I've heard low pressure water but I dont want to get moisture in anything that will harm it.
Discussion Starter #8
No problem dude and I am trying to figure this out as well lol
Is your motor apart? If so, I don't see what it would hurt to use low pressure water. Especially if you are going to do a full honing.
Banned
I don't really know in your area. Last time I had one done it was around $8-$12 a hole for bore/hone and cleaning was around $25. I imagine prices have risen considerably since then.
Really low pressure hot water (like a gentle rain) and a good engine degreaser. You want to take steps to ensure water does not get into any electrical & ignition components. It is best to cover them with plastic bags and hand clean them later.
1 - 10 of 10 Posts
