1 - 20 of 31 Posts
Discussion Starter #1
Thinking about putting one one my mustang but not sure if its worth it? Can you tell a difference in horsepower? How much would it cost?
Yes big difference and different tone .. and just get a civic one off craigslist that seems like it fits. If it has holes or holes you don't need just black tape them
Banned
Or i can give you my build list for the one i custom made
Banned
That would be very helpful
OK here is my build list
I will give prices too, it's been a while:
Pipe( I had my local exhaust shop bend me a piece of exhaust pipe to match up with the stock air box) $10.00
2x Rubber Couplers (got them from the hardware store, I think they are 2.5" dia. perfect fit) About $2.50 each
Cone Filter (from Advanced Auto Parts) $23.99
Mass Air Flow(MAF) Adapter (also from Advanced Auto Parts) $10 or $15
Also you will need bolts to attach the MAF to the MAF adapter
And I Plasti-Dipped my pipe, purely for looks, and you will need some way to mount it, I just took some sheet metal I had laying around for it to sit on
Good Luck!
If you have any questions feel free to message me, or post it!
Discussion Starter #9
My dad said something about a box to put around the filter so it's not pulling the heat from the engine. Where would I get one?
Banned
You might be able to find one online somewhere but I've heard of and seen people use a Rubbermaid plastic 5 gallon trash can and cutting it to fit, or you could get some sheet metal and make one
Discussion Starter #11
I'm guessing it'll make more HP if I have a box?
Banned
Yeah a little bit because the air is cooler than without, mine doesn't have a box yet :/ I'll probably spend the $4 or $5 on a Rubbermaid and try it and if I do I'll le y'all know how it works :)
Banned
itsA4cylBro said:
My 88 has one going all the way down getting all the cold/fresh air :)
Just don't go thru deep water or a puddle! Lol
Discussion Starter #15
Alright! Do you know of any other way to get more HP?
Remove your cats . Get a magnaflow muffler sounds mean. Get some lightweight pulleys just not the crankone .
---------- Post added at 10:33 PM ---------- Previous post was at 10:32 PM ----------
Just make your cat removal bolt on so when u need to pass smog . Oh and use 91 gas :D
Discussion Starter #18
Just so you know I'm only 17 and don't understand some of this. Haha
Banned
The catalytic converters are the big oval shaped things, one you can see from under the hood and the other one is under the car, and the pulleys are what tour belts run on and he forgot a space between crank and one, so light pulleys other than the crank pulley and smog is the emissions control stuff some states randomly check vehicles to make sure they have the proper equipment. (I don't know what you don't know that's why I covered all of it :))
1 - 20 of 31 Posts
