1 - 4 of 4 Posts
Discussion Starter · #1 ·
Hey guys, my new set of Upper and Lower Control arms came in today. My dad was going to help me, but he got called to work early. How hard is the install? I'm somewhat Mechanically inclined. Could me and a friend do it?
You and your friend should be able to do it for sure. I'm think they're almost identical, but on my sn95, it took maybe an hour just to access both by myself. I didn't swap them but I did take them out with no problem.
Discussion Starter · #3 ·
Ok. Cool. Did you have to take out your gas tank?
You do not have to drop the gas tank, just make sure you use jack stands and have it up high enough to get under at least to reach the upper inside bolts. Pull rear sway bar off completely to put back on last. Take shocks loose both sides, then support rear end and should not have any problems
1 - 4 of 4 Posts
