1 - 4 of 4 Posts
Discussion Starter #1
I have a 1990 LX Convertible 4 cyl
The top stop working it will not go up or down
I checked the fluid in motor and looks like it full
When trying up or down all I hear is a clicking sound
Does anyone know what it could cause the top not to go up or down
Thanks
Pull the panel and unhook the cylinders. Try to motor. If you still get a click I would assume the motor is bad.
The positive about disconnecting the cylinders is that you can operate the top manually if you need to.
You should hear a buzz coming from the hydraulic motor.
Discussion Starter #4
1 - 4 of 4 Posts
