1 - 20 of 21 Posts
· Registered
Discussion Starter · #1 ·
Check engine light is on. Had code read and P0455 came up "a large leak in the fuel vapor system" I need to know where the carbon canister, the fuel tank pressure sensor and the canister purge valve are located on a 2000 mustang convertable so that I can check them out.
Thanks to Jorge in directing me to the correct place to post this as I am a new subscriber.
· Registered
Re: Diagnostic code PO455
try twisting the gas cap when you put it back on. the vapor leak is usually due to the gas cap not being fully tightened when you put it back on after fueling up. make sure that it clicks.
· Premium Member
go to autozone and get the codes read they will tell you what they are
· Premium Member
He already did that...
· Premium Member
Code:
: P0455 - EVAP Control   : The PCM monitors the   : *  After-market EVAP   : Check for audible      :
: System Leak Detected   : complete EVAP control  :    hardware (such as   : vacuum noise or        :
: (No Purge Flow or      : system for no purge    :    fuel filler cap)    : significant fuel odor  :
: Large Leak)            : flow, the presence of  :    non-conforming to   : in the engine          :
:                        : a large fuel vapor     :    required            : compartment or near    :
:                        : leak or multiple small :    specifications      : the EVAP canister and  :
:                        : fuel vapor leaks. The  : *  Disconnected or     : fuel tank.             :
:                        : system failure occurs  :    cracked fuel EVAP   :
:                        : when no purge flow     :    canister tube, EVAP :
:                        : (attributed to fuel    :    canister purge      :
:                        : vapor blockages or     :    outlet tube or EVAP :
:                        : restrictions), a large :    return tube         :
:                        : fuel vapor leak or     : *  EVAP canister purge :
:                        : multiple fuel vapor    :    valve stuck closed  :
:                        : leaks are detected by  : *  Damaged EVAP        :
:                        : the EVAP running loss  :    canister            :
:                        : monitor test with the  : *  Damaged or missing  :
:                        : engine running (but    :    fuel filler cap     :
:                        : not at idle).          : *  Insufficient fuel   :
:                        :                        :    filler cap          :
:                        :                        :    installation        :
:                        :                        : *  Loose fuel vapor    :
:                        :                        :    hose/tube           :
:                        :                        :    connections to EVAP :
:                        :                        :    system components   :
:                        :                        : *  Blockages or        :
:                        :                        :    restrictions in     :
:                        :                        :    fuel vapor hoses    :
:                        :                        :    /tubes (items also  :
:                        :                        :    listed under        :
:                        :                        :    disconnections or   :
:                        :                        :    cracks)             :
:                        :                        : *  Fuel vapor control  :
:                        :                        :    valve tube assembly :
:                        :                        :    or fuel vapor vent  :
:                        :                        :    valve assembly      :
:                        :                        :    blocked             :
:                        :                        : *  Canister vent (CV)  :
:                        :                        :    solenoid stuck open :
:                        :                        : *  Mechanically        :
:                        :                        :    inoperative fuel    :
:                        :                        :    tank pressure (FTP) :
:                        :                        :    sensor              :
· Registered
Discussion Starter · #8 ·
To all of you that replied to my thread on code PO455:
IT APPEARS THAT MOST OF YOU DID NOT REALLY READ IT. IT STATED THAT I HAD ALREADY CHECKED THE CODE AND IT IS PO455. I NEED THE PHYSICAL LOCATION OF THE PARTS LISTED. I HAVE CHANGED THE GAS CAP ALREADY.
DOES ANYONE ACTUALLY GO UNDER THEIR CARS TODAY AND DO ANY WORK ON THEM??
· Premium Member
calm it down a few notches
· Registered
Discussion Starter · #13 ·
You are right!! Just have been burned a lot on another site by people that just seem to want to be seen on the internet and not really help a guy out. I'll behave better in the future.
· Premium Member
Sometimes we get so caught up in trying to answer all the questions we don't have time read them right lol. At least you've got the right info now. Keep us updated with what you find.
· Registered
Discussion Starter · #17 ·
I'll report back when I get some time after the holidays and the arrival of our first grandbaby! The light has been on for 6 months now with no ill effects so a few weeks longer won't hurt :) At least now I have a starting point.
· Registered
I would dare to suggest that before you do any checking or troubleshooting, reset the ECM and check if it shows up again. Some of these evap codes show up once (due to causes you have read already) and may have been corrected (the new gas cap). I'm assuming a reset was not done after you changed the gas cap,.....if you did.......troubleshooting is required. GL
· Registered
Discussion Starter · #19 ·
Thanks for the comeback. I have reset the ECM by disconnecting the battery overnight. I did this both after the code was read intially and after the gas cap change. After about one week the light returned. I am hoping that wat I did was good enough to reset the ECM if not what should I do?
1 - 20 of 21 Posts
