Door lock actuator on '14 base model: do I have anti-theft?
831 Views 2 Replies 2 Participants Last post by  parkrndl
So my driver's door lock no longer works with the remote or the electric switch on the door. I assume I need to replace the door lock actuator. I looked them up on RockAuto and there's two different part numbers: with or without Anti-Theft. I thought they all came with Anti-Theft. My car is as base as a base model can get, but when you leave the car, there's a little red flashing LED in the dash. Is that actually what they mean by anti-theft or is there a higher optional level of factory alarm/anti-theft system?
When I looked at the details on the website, it says the one without anti-theft has a 4-terminal plug, and the one with anti-theft has a 6-terminal plug.
Thanks for any insight...
See less See more
1 - 3 of 3 Posts
There is an option called "active anti-theft" and it has a sensor on the map light housing. I know because of this.....
You want the regular actuator unless you have a hole there. The ECU has its own system and that is the flashing red light.
See less See more
That's exactly what I needed to know. Thanks!
1 - 3 of 3 Posts
