1 - 20 of 31 Posts
Discussion Starter #1 (Edited)
Looking to pick this up along with an exhaust tonite.... I do not have an extensive tool collection, nor experience. How difficult is the installation? Really only looking to do mods I can handle myself, will build my way up to the harder ones. This is a make or break question for me on this particular purchase. Any help here is appreciated
That has nothing to do with the driveshaft...
I guess I misunderstood it ... I thought pinion angles were a concern with one piece drive shaft installations? However, I have no idea what any of this means ... which is why I decided that this was not something I was going to do myself.
I mean, it's of concern, but the driveshaft shouldn't have a big impact. Lowering the car is what causes the pinion angle to change, and its adjusted with an adjustable upper control arm.
I did mine with the rear up on jack stands in my garage. Wasn't hard at all. Take out some bolts, swap shafts, put bolts back in.
SolidRRaxle said:
Napoleon, have you done this mod before? Trying to do it with just a set of ramps.
No, but it should be relatively easy. I would install a driveshaft loop while I was down there.
Discussion Starter #11
Thanks. I picked up the BMR loop. Figure if I acrew it up, should have something there to catch it so it doesn't hit the pavement at 60 mpg and rip off my axle
---------- Post added at 01:02 PM ---------- Previous post was at 01:01 PM ----------
Nice, that is exactly what I was hoping it would be.... I should've waited to purchase but I'm like a little kid with this stuff. Purchased it about an hour or so after I posted this thread
So, then I am to understand that there really ISN'T more to it than simply bolting in a new drive shaft? If so, that's something I am quite happy to have misunderstood. :)
I don't think so...
The Blue Dragon
such a great mod too from everything I hear, too bad it's something we need to do ourselves though, I think at the very least it should have had a one piece from factory... and if they're so worried about MPG's it would've benefitted to have aluminum
I agree a one piece would have been nice to have come from the factory. Beings at 11,240 miles I twisted the factory two piece one.
Holy smokes ... what kind of power were you putting down to do that? I agree though, the two-piece shaft is garbage. I hate how it's always clanking when you engage the clutch from load... if I had a dollar for every time I had to explain what that noise was ...
+1, lol. Same here
While I haven't messed with the Mustang's driveshaft, I have removed & installed the one on the project car so many times I've lost count. Every time on jackstands. It's a pretty simple part. I'm sure once you get under there it will be obvious how easy it is.
No more power than ford put in the car.
1 - 20 of 31 Posts
