1 - 5 of 5 Posts
Discussion Starter · #1 ·
i just wanted to know is the roots blower off a moderen GTP a m-90? b/c i think they have a better flow then a the old t-birds. thanks for the help
try a grand prix forum they would no more, if you want it on a stang i think itd be more of a hassle than its worth, sorry that i couldnt help much..
wont work, i talked to lots of techs at my old job, and they said your car would be down for a long time tryin to fit it on there, and then to mix all the extra stuff you need. 3800's are not the same as a 3.8. diffrent intake, and some internals. just fyi.
Discussion Starter · #4 ·
no no with this new roots system thats someday coming out, its doesnt matter weather its a GM or Ford as long as its an M-90 they can make it work for free.
it wont bolt up to your car and even if it did the bottom end cant take alot of boost so... you will have to keep the boost turned down which will make you make less hp, but you will still make good tq due to the roots blower...however a centrifugal SC (procharger) will let you run more boost, higher up rpm peak boost, make more hp and less tq than the roots (still same tq numbers or close to it just takes more psi to do it, basically it would be well worth it if the bottom end could take alot of punishment, and it may can just be leary.... and its alot of headaches to set up.
1 - 5 of 5 Posts
