1 - 11 of 11 Posts
Discussion Starter #1
Have stock 66 Mustang with original fuse panel. Once in a while my radio,heater, turn signals will quit working. The lights still work and no bad fuses. If I shut off the engine and restart they come back on. Any ideas?
You should look into re-wiring just for the reliability factor. But sounds like could be the fuse panel itself
Banned
Sounds like you are losing power from the ignition switch.
Try to find a diagram that shows the ignition switch wiring and trace the wire that energizes the fuse box.
1 - 11 of 11 Posts
