1 - 6 of 6 Posts
schmitty426 said:
Dose anybody know of a good way to clean an engine bay of dirt and grime?
1) towel
2) simple green
3) elbow
4) Grease for said elbow.
schmitty426 said:
Where can I get this simple green?
Any hardware store.. Maybe even target.. Cleaning section, not specific to automotive.
nhcowboy said:
1) towel
2) simple green
3) elbow
+1
If it needs light duty cleaning or just a touch up thats the best way to go.
For the heavier stuff I use a cleaner similar to simple green. I start by covering up parts that need to be covered. Airbox, fuse box, alternator, distributor cap if equipped, and the battery. I lightly mist the engine bay with water holding it off to the side. Less is more. After I lightly rinse I spray cleaner, I get a soft brush and old clean towels and some elbow grease to start. Then, I rinse again. After you get it to your liking dry it off it real good. A Leaf blower works good for that. At this point I remove everything and start the engine you may get steam not a big deal. Stop wipe up steam. Then I use Sprayway instant shine. Whatever process you use just make sure the engine is cold.
1 - 6 of 6 Posts
