1 - 7 of 7 Posts
Discussion Starter · #1 ·
So my engine coolent is on but the coolent level is filled up so I'm guessing its the sensor. Is it an easy fix?
Is it full at your cross over pipe?
Im in the same boat, light came onthe after I changed the radiator,, was told to in plug the sensor then on/off a few times if it stays off while un plugged and on when plugged in its the sensor,,, or just clean it and try it out
Discussion Starter · #5 ·
We're is the sensor located? If it is the sensor how much is a new one and can I replace it myself
There's 2, the one in the right side of the cross over pipe(looking at the car) and the one in the tank. I've never changed em but shouldn't be too much work,, also was told to just replace the tank
1 - 7 of 7 Posts
