1 - 11 of 11 Posts
Discussion Starter · #1 ·
Hi all, I have a weird noise from the engine when its cold, I hear it when I let go of the gas just before a shift.
Sounds like a wrist pin type noise or piston slap?
Is this common to mach1's?
Warranty time? only 26000 KM's
Hmm, I would DEFINATELY take it to get looked at. It's still under warrenty so you've got nothing to lose.
You aren't hitting redline with the engine cold are you?
The chevies I had always had bad bad cases of piston slap when the engines were cold.. the engines lasted a long time.. that doesn't sound typical of a DOHC 4.6.. or a 4.6 at all for that matter
I'd get it checked out
Banned
Yep its warranty time
One of your pistons is sticking
Trying to find out but its a recall I believe (If its not it should be) Contact KrazyPony on this site.
He owns a 03 Mach 1 and knows about the problem
Def take it to the dealer and get it fixed
Discussion Starter · #5 ·
No where near it I shift between 2500 - 3000 and don'r drive it hard when cold.
looks like an oil pressure gauge is in your future:eek:: but go get it checked out from the dealer
I can't find any info on any recalls nor SSMs/TSBS concerning knocking, just engine ticking...
Discussion Starter · #8 ·
I found similar people with this issue. One guy described exactly like I do... bearings rolling in a can.
Turned out he chain tensioners were bad. Replaced them and the noise was gone.!
I have a red 03 Mach1, I have the same problem, engine noisy just before shifting when cold. Just got it back from Auffenberg Ford here in O'Fallon Illinois. Seems they had a Ford Engineer drive it and another yellow 03 Mach they had on their lot. They both had the same noise. Their conclusion "it's normal for that model". I don't buy that, but the Ford Complete care warrenty did, cost to me $100 deductable, and a noisy engine. I really like my Mustang, but this will irritate me every time I drive it now.
Make em fix it man...you've already paid the deductible, they didn't fix the problem.
I plan to take it to another dealer, Lost confidence with this one. I'm sure if they made this kinda noise new, Ford would not have sold so many!!
1 - 11 of 11 Posts
