1 - 9 of 9 Posts
You can put almost anything in there, but with more power you're gonna have to upgrade more than the engine, like the rear end, brakes, etc. anything that won't be able to handle that much power
I think it would be pretty awesome to put that motor into a '96. You'd definitely get some looks when you pop the hood or when you haul ass with a sleeper like that! But if that motor is going into a '96 v6 then you will have to upgrade the transmission, rear end, drive shaft, etc. If it was a GT it could probably hold up fine, but a v6 will have some issues.
Discussion Starter · #6 ·
Dang v6 -_-
The only benefit to doing this to a gt is having an 8.8 rear in the car already, otherwise it's just as much work
1 - 9 of 9 Posts
