Inside of airbox with Collar from sound tube pushed through hole on inside of airbox and bead of RTV sealant sandwiched in between to seal
Collar from hose that you push through airbox from inside (pic is what it looks like on outside before sealing it with RTV
Connected to back of airbox
The sound tube comes with a collar on the end that you just pull off and then insert from the inside of the airbox and seal. Then you slide the pvc onto the hose and onto the other side of the collar that sticks through.
I did cut the hose so that I would not have so much snaking through. If you plan on going to the intake tube baffle you will use the entire length of hose though.
---------- Post added at 08:59 AM ---------- Previous post was at 08:57 AM ----------
I have pics of the hose modifications, bolts, and other shots, though blurry and dark but may give you a better idea... or confuse you IDK lol but if you want those too lmk.
