1 - 20 of 25 Posts
Discussion Starter #1
Well here's everything I have .. Performance wise
Pypes headers
H pipe
Pypes catback
BBK cai
Bbk tb
Steeda tb spacer
Sct tuner
8.8 gt rear end 3:73 gears
Custom made one piece drive shaft
Eibach sway bars an control arms
Hr lowering springs
Eibach coil overs
Gms coil pack street thunder wires ngk plugs
Boss 302 brace
What else an I missing minus boosting it or throwing nitrous in it ??????
jamin22786 said:
I thought injectors only help forced air? New throttle body? Check out super six motorsports
Yea he said he wants to do f/I or spray(which you shouldn't do imo, supercharger or turbo would be better) and throttle body would be a waste of money if he's doing s/c or turbo because most likely that will all get replaced
Ah, I guess I read that differently. Makes sense. Yeah, if you've got the money, chargers are best, but nitrous is a big boost for the money and can be safe if done correctly with a window switch.
Discussion Starter #6
An I'm debating it I should boost it or not an I'm not getting spray it's a daily driver lol but does anyone have the stroker kit cams or heads for the v6 !?
Nitrous functions the same as any forced induction. If you use it correctly (at safe levels at the correct rpm range) there's no danger.
Wmcgrattan said:
I'm not sure it's the steeda spacer from am
Tom morana racing makes parts for the 4.0 I believe. Even a 4.5 stroker
---------- Post added at 12:10 AM ---------- Previous post was at 12:08 AM ----------
Only a 4.3l for the 4.0s.
---------- Post added at 12:12 AM ---------- Previous post was at 12:10 AM ----------
AVAILABLE 2005-2010 Stroker Kits and short blocks!!
4.3L Stroker Kit consists of-
cast steel crank, forged I-beam connecting rods, forged pistons, performance piston rings, Clevite or SpeedPro rod and main bearings, fully balanced $2,600. US.(for either) kit
Stroker short block- incl. all above 4.3 Stroker components plus, block(bored & honed) assembled- $3,850. US. OHV engines (OHC engines $4,550.) US.
Performance camshaft(your choice,OHV only)add $400.00 US.
Stroker long block or complete also available-prices depending on your choice of head stage.
All short block, long block, or complete Stroker Engines require a $300.US. (core charge)
http://www.moranav6racing.com/category.html?CategoryID=32
Discussion Starter #11
Yea my plans were to fully build my 6 but I decided to wait an buy a v8 later after college
Hood and a body kit. Louvers and scoops. These cars can lool so sick and unique. I have a cervini ram air hood and a eleanor body kit. AM side scoops and louvers and a ducktail spoiler. While going down the freeway i had guys driving brand new 90,000$ cars doing everything they could to look at my car.
Discussion Starter #17
I have window louvers an side scoops but I don't like the Eleanor body kit idk what it is an I have a hood but I might get that spoiler though
DAG 01 said:
How much horsepower would the 4.3 stroker kit put out?
Fully build N/A power 300rwhp
Fully build blown power at 20psi(estimate) 600rwhp give or take at the blown part, depends on blower.
---------- Post added at 12:47 PM ---------- Previous post was at 12:46 PM ----------
Post some pics or make an albumn, I've always wanted to see ur car
Discussion Starter #19
My car is fully built the only pieces I'm missing is a turbo or super charger an engine internal work which I'm planning on in a couple of years because I plan on keeping this car forever lol but I'm all out of ideas for other parts to add to it
Slowly put parts together
1 - 20 of 25 Posts
