This has been a work in progress for a few months now, and I believe I've finally found the correct combination of things to make my shifting problems a thing of the past.
I had issues changing gears, gears not engaging, and with finding the correct gears. To fully disclose, this is my first 6-speed manual car I've owned, though I've owned manuals for many years & learned to drive on a 4-speed manual Mustang. This MT-82 has been particularly difficult to learn and get good with, partially because I only drive it on nicer days, so I have not had thousands of miles to get used to it.
The changes made have made a tremendous difference in the experience though. I've added or done the following
1. Redline Synthetic fluid change.
2. New Shifter
I removed the stock setup and replaced the shifter, bushings, and all the goodies with an MGW setup. Far and above the best money ever spent here, the engineering and quality are 2nd to none.
3. Changed the clutch pedal height/depth.
I bought a clutch pedal extension. Mustang Pedal Extension link to Bondra Performance Engineering I thought this was ridiculous at first and it damaged my pride a bit thinking that maybe I was too short to drive my own car...and causing a few jabs from friends at my expense.
At 5'10", I found myself sitting way too close to the steering wheel so I could get the clutch all the way in while accelerating, making me uncomfortable, not to mention I was kicking the door panels every time I got out. This simple little thing saves all that, and aligns the pedals as they SHOULD be, giving an offset for the pedals that I think they should have had from the factory.
Now when I drive, no issues, the clutch pedal goes all the way down, and I can smoothly & accurately select the next gear.
2. New Shifter
