1 - 20 of 53 Posts
Discussion Starter #1
I want to put fog lights on my car which they didn't include when they made them. So I was seeing if anyone has done it how much it is. I saw a whole kit on vmp tuning for $180 which I thought was expensive. I was looking for a cheaper route. I eventually want hids in them too. Any help would be great.
You can prolly get them cheaper off eBay and they will work fine. Splice them in with your headlights and I'm assuming they will work fine and turn on with whatever you spliced the wires into.
I just bought the fogs from american muscle and they came with regular bulbs. Bought the connection to the bulb at an auto place n just wired em to my headlights
Discussion Starter #4
What kind of wire did you buy from the auto store? Exact details would be great
just some 12 gauge wire will work...get a small spool or black and red. get some female crimp ends as well that are small enough to slide over the bulbs terminals (same thing has having a harness)
take the red wire and run enough length to go from the constant power wire for the ambers (turn signals) to the fog lights. you can find this wire by pulling the headlight switch and using a test light to see which of the three wires is getting power. splice in the red wire..now when you pull the headlight switch your fogs will get power
now run the black wire from the fog lights up to the headlight ground bolts. there is one in front of both headlight housings and easy to find.
this is a good way to wire up fogs for just a couple bucks if you have spare wire laying around. or a $10ish job if you're buying the wire and crimp ends
Discussion Starter #6
Ok Im buying a OEM foglight switch for my 04 and a pair of smoked fogs from AM. What else would I need ? Or is that all ?
iv been thinking the same iv been trying to study the wiring diagram so i can have the fogs on wen i turn on my ambers and i wana use hids not regular ****ty ones i was gana look at the connection for the hid and see if oriellys or vato zone has it and wire it up the kit from ford is like almost 200 i found one on ebay for like 80 but i dnt wana use a seperate switch i want it to be oem
Discussion Starter #8
Ya, I just bought smoked fogs and a OEM switch on amazon for $90. Hopefully I can find a way to get it all together and right. And definetly gotta have hids
So basically you buy a pigtail right? It has 2 wires one gets spliced into the brown wire and the other gets grounded?
Thanks for posting the video! I think I am going to mount my lights as soon as they get here. Like your stang by the way.
One question though, your light holes look kind of rough.. Do the lights not fit flush in the holes? Did you try sanding/filing them for a cleaner look?
Discussion Starter #15
I did that today... But the left fog light seemed to not fit quite as well as the other. It was a little high.
Did what today? Cleaned them up? Hopefully mine will fit well :cool:
edit: also, looks like no spoiler on your car? If thats true did your stang come like that or did you remove it? If you removed it did you just use the plug trick?
I really want the remove my spoiler but not sure how it would look and if the plugs would look that bad. Dont have the cash to get the whole trunk lid panted.
Discussion Starter #17
I cleaned up the fog light area better today. And the mine came with the spoiler I took it off to see how it would look and I liked it so I went to the store bought four plugs and put them in. Cost $1 and since my cars white I didn't have to buy touch up paint. The plugs don't look too bad either besides if I want the spoiler back it takes 2 minutes.
Ok thanks! I might have to give that a try as well. Already got some touch up paint. Kind of going for a simple/sleeper look and not really feeling the spoiler either.
been a few weeks since i was wingless...maybe i'll pop mine back off for a month or so. i switch back and forth when i get bored
1 - 20 of 53 Posts
