1 - 3 of 3 Posts
The stock in tank fuel pump is sufficient for stock engines. If the engine is modified to use more fuel such as bigger injectors, manifolds,heads etc, then you should upgrade your fuel delivery system to keep up with the demand for fuel but adding a high flow pump will not by itself increase horse power.
1 - 3 of 3 Posts
